and gas is leaking from them (under pressure) into block. Do not crank the engine until you get this fixed -- you may have already damaged the engine (ie., hydrolocked)...
Remove the fuel rail (still connected) to gas and wires and then turn the key - looking to see which injector is leaking out the bottom. Could also be an injector issue too - but more likely a leaky o-ring.
